Hi there,
is it possible to limit the access to the internal network for one specific user? For example
User A has access to host01,host02
User B has access to host02,host03,host04?
Best regards
Simon
VPN Bridge: Limit Access to internal ressources for one user
Re: VPN Bridge: Limit Access to internal ressources for one
Yes, this is possible. When in the VirtualHub management window, click Manage Access Lists, click New
In there you will have the options to create "pass" or "discard" rules.
You can specify the users or groups of users in the "Source Name" section. In the Destination IP section opposite, select the IP subnet or host that you want to "allow" or "deny" access to (and which protocols). Once you hit OK, it will become active.
Rgds
Paul
Rgds
Paul
