Can't connect router (client) to pc (softether vpn server)
Re: Can't connect router (client) to pc (softether vpn serve
Post by thisjun » Fri Feb 26, 2016 7:15 am
Did you check a server log?
dmun
Post by dmun » Fri Feb 26, 2016 4:05 pm
fatalick wrote:
> I have successfully connected pc with softether vpn client to pc with
> softether vpn server.
> But I can’t connect router (l2tp/pptp client) to pc (softether vpn server)
I see similar behavior with my install; softhether client works great but L2TP doesn't work at all. If you can post your relevant softether server logs as thisjun suggested then we can see if it's a DHCP issue.
