Simple cascade experiment
shaglord
Post by shaglord » Wed Apr 13, 2016 8:28 am
Hey
I'm trying to cascade connect one server onto another. They are both on different sub nets.
The cascade connection shows as online but the two virtual hubs can't communicate in between.
What could it be that I'm missing?
Also how to avoid clients dhcp requests and other potential loop triggers to occur? Is the default softether cascade configuration able to handle this somewhat?
Thank you for reading! Thumbs up... /s
UkrZilla
Re: Simple cascade experiment
Post by UkrZilla » Wed Apr 13, 2016 11:49 am
You should use LAN to LAN connect using L3 IP routing
http://www.softether.org/4-docs/1-manua ... Routing%29
