Connection to the server failed
giulius540
Post by giulius540 » Tue Jun 14, 2016 3:52 pm
Hi
I carefully installed a SoftEther VPN Server on a Windows machine and a SoftEther VPN Client on another machine. The Server is online, but the client is unable to connect to the server.
The error is: Error Code 1 - Connection to the server failed...
I tried any combination of ports.
Please, could you help me?
Thank you
Giuliano
erkwok
Re: Connection to the server failed
Post by erkwok » Wed Jun 15, 2016 3:47 am
would it be the windows firewall issue on the server machine?
try to disable the server firewall for testing. if it works, reenable the firewall and allow the specific port(s).
giulius540 wrote:
> Hi
> Thank you
> Giuliano
giulius540
Post by giulius540 » Wed Jun 15, 2016 4:31 am
Thank you for your reply.
I disabled the windows firewall on the server machine, but I am unable to connect.
Giuliano
erkwok
Post by erkwok » Wed Jun 15, 2016 11:28 am
did you check the log file?
what are you getting from there?
> connect.
> Giuliano
giulius540
Post by giulius540 » Wed Jun 15, 2016 5:35 pm
Thank you for your assistance.
I discovered the problem. The server is behind a NAT Router.
If I set a port forwarding to the server IP address, I am able to connect.
Unfortunatedly I need to install the server on a network where I have no possibility
to do any settings..
Do you know any workaround?
Thank you again
erkwok
Post by erkwok » Thu Jun 16, 2016 2:53 am
I think this may help
https://www.softether.org/4-docs/2-howt ... .VPN_Azure
> > connect.
> > Giuliano
erkwok
Post by erkwok » Thu Jun 16, 2016 2:54 am
> possibility
> Thank you again
giulius540
Post by giulius540 » Fri Jun 17, 2016 4:14 pm
Thank you very much for the suggestion.
Now it works!
I appreciate your support.
Giuliano
