CPU 100%
jonesalmeida
CPU 100%
Post by jonesalmeida » Thu Feb 01, 2018 5:14 pm
I have 516 active sessions on my VPN network, I have a server with two E5-2630 v4 processors, with 40 cores, yet my CPU stays 100%.
My config below:
# Software Configuration File
# You may edit this file when the VPN Server / Client / Bridge program is not running.
declare root
uint ConfigRevision 122
string Region BR
declare DDnsClient
bool Disabled false
byte Key 3rcppHsNxwJsHBXdAdom90JFw1I=
string LocalHostname q2zvgvk4fb
string ProxyHostName $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
declare IPsec
bool EtherIP_IPsec false
string IPsec_Secret vpn
string L2TP_DefaultHub RobinVpn
bool L2TP_IPsec false
bool L2TP_Raw false
declare ListenerList
declare Listener0
bool DisableDos false
bool Enabled true
uint Port 443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
declare LocalBridgeList
bool EnableSoftEtherKernelModeDriver true
bool ShowAllInterfaces false
declare ServerConfiguration
bool AcceptOnlyTls true
uint64 AutoDeleteCheckDiskFreeSpaceMin 8589934592
uint AutoSaveConfigSpan 300
string CipherName RC4-MD5
uint CurrentBuild 9656
bool DisableDosProction false
bool DisableOpenVPNServer true
bool DisableSSTPServer true
bool DontBackupConfig false
bool EnableVpnAzure false
bool EnableVpnOverDns false
bool EnableVpnOverIcmp false
byte HashedPassword DwcBp8CRDS1rvI91NdIaH+jRAIY=
uint KeepConnectInterval 100
uint KeepConnectPort 80
uint KeepConnectProtocol 1
uint MaxConcurrentDnsClientThreads 512
uint MaxConnectionsPerIP 256
bool NoDebugDump false
bool NoSendSignature false
string OpenVPNDefaultClientOption dev-type$20tun,link-mtu$201500,tun-mtu$201500,cipher$20AES-128-CBC,auth$20SHA1,keysize$20128,key-method$202,tls-client
bool SaveDebugLog false
byte ServerCert MIID9DCCAtygAwIBAgIBADANBgkqhkiG9w0BAQsFADB5MSIwIAYDVQQDDBlmdXR1cmFyb2Jpbi5zb2Z0ZXRoZXIubmV0MSIwIAYDVQQKDBlmdXR1cmFyb2Jpbi5zb2Z0ZXRoZXIubmV0MSIwIAYDVQQLDBlmdXR1cmFyb2Jpbi5zb2Z0ZXRoZXIubmV0MQswCQYDVQQGEwJVUzAeFw0xNzA5MDQxOTUzMjlaFw0zNzEyMzExOTUzMjlaMHkxIjAgBgNVBAMMGWZ1dHVyYXJvYmluLnNvZnRldGhlci5uZXQxIjAgBgNVBAoMGWZ1dHVyYXJvYmluLnNvZnRldGhlci5uZXQxIjAgBgNVBAsMGWZ1dHVyYXJvYmluLnNvZnRldGhlci5uZXQxCzAJBgNVBAYTAlVTMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAr36QL7621zLD0afgPhmy7u8FK+Qmfwt2ii3KYwpZNC+yXYrXBbDtF/4Dssc+Oh26IbNb9qWPkwoPjITJ+1VKsWHpola0TvHOyhG6LhnIMPeG+LrfPjedRCqGpSGtkdJ9eYMUX+EtNUV/DRLEa1C6x7Z2g54BxfW8mIo0YTVUon1Gr5Big8MUDsnL9oVGPYipSn4a5lHpEmRgkQ8pghL1+G5heQo3t2PkJa0n1wJaXLoWbqUQGNaS4imf4jBrXNMdgT+UNh1yZKoYoyyt/92N/DMDxP6Q/d6F/wiYoyFS/KzZAyyAEn0ZRc7CL9VWsgwcDHdMJcqIPfC9oYwgI8BMgwIDAQABo4GGMIGDMA8GA1UdEwEB/wQFMAMBAf8wCwYDVR0PBAQDAgH2MGMGA1UdJQRcMFoGCCsGAQUFBwMBBggrBgEFBQcDAgYIKwYBBQUHAwMGCCsGAQUFBwMEBggrBgEFBQcDBQYIKwYBBQUHAwYGCCsGAQUFBwMHBggrBgEFBQcDCAYIKwYBBQUHAwkwDQYJKoZIhvcNAQELBQADggEBAGj8dj/dZvD6+3O1vKXRsL9qI0XU2i0vUgq1bHIUbGtcLuSehVE9GwlPM7m5ezPTAMREDaaqgVc3gmcSX0Bhfsfy+7ACIFOTrU2ubLK2DGhzddsow0HTO4i50Cd4Y34FPjXsT8c8eRHSSN0+BtkPVH7PNHUSyP7eKHa6v8qTzIB+useG5FNHwsK3v5Ex1whR97IqbN7WTBhyf7eSzD7xpXLYtuNYUzjR1XJivK9pFu7OnSnUw90dcmRHQrk6l5GJS0ao4xZB1oZou3VuWuw985rXgIAD22htdSm5VWuUh68NBsq1fXNyNGQApS1gSZ+hERkXGSP6ktedhlTi/GwAvGs=
byte ServerKey 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
uint ServerLogSwitchType 4
uint ServerType 0
bool StrictSyslogDatetimeFormat false
bool Tls_Disable1_0 false
bool Tls_Disable1_1 false
bool Tls_Disable1_2 false
bool UseKeepConnect true
bool UseWebTimePage false
bool UseWebUI false
declare GlobalParams
uint FIFO_BUDGET 10240000
uint MAX_BUFFERING_PACKET_SIZE 2560000
uint MAX_HUB_LINKS 1024
uint MAX_IP_TABLES 65536
uint MAX_MAC_TABLES 65536
uint MAX_SEND_SOCKET_QUEUE_SIZE 2560000
uint MAX_STORED_QUEUE_NUM 1024
uint MEM_FIFO_REALLOC_MEM_SIZE 655360
uint MIN_SEND_SOCKET_QUEUE_SIZE 320000
uint QUEUE_BUDGET 2048
uint SELECT_TIME 256
uint SELECT_TIME_FOR_NAT 30
uint STORM_CHECK_SPAN 500
declare ServerTraffic
declare RecvTraffic
uint64 BroadcastBytes 99533992536
uint64 BroadcastCount 846565969
uint64 UnicastBytes 8478601494598
uint64 UnicastCount 29999059723
declare SendTraffic
uint64 BroadcastBytes 21871743331163
uint64 BroadcastCount 166301524672
uint64 UnicastBytes 8464163506722
uint64 UnicastCount 29846175752
declare SyslogSettings
string HostName $
uint Port 514
uint SaveType 0
declare VirtualHUB
declare RobinVpn
uint64 CreatedTime 1504522392578
uint64 LastCommTime 1517472850458
uint64 LastLoginTime 1517472839614
uint NumLogin 146541
bool Online true
string RadiusRealm $
uint RadiusRetryInterval 0
uint RadiusServerPort 1812
string RadiusSuffixFilter $
byte SecurePassword /dvXigRZ3sIuPc+T0dNVwYxz0bQ=
uint Type 0
declare AccessList
declare AdminOption
uint deny_bridge 0
uint deny_empty_password 0
uint deny_qos 0
uint deny_routing 0
uint max_accesslists 0
uint max_bitrates_download 0
uint max_bitrates_upload 0
uint max_groups 0
uint max_sessions 0
uint max_sessions_bridge 0
uint max_sessions_client 0
uint max_users 0
uint no_cascade 0
uint no_change_access_list 0
uint no_change_cert_list 0
uint no_change_crl_list 0
uint no_change_groups 0
uint no_change_log_config 0
uint no_change_msg 0
uint no_change_users 0
uint no_delete_iptable 0
uint no_delete_mactable 0
uint no_disconnect_session 0
uint no_enum_session 0
uint no_offline 0
uint no_online 0
uint no_query_session 0
uint no_read_log_file 0
uint no_securenat 0
uint no_securenat_enablenat 0
declare CascadeList
declare LogSetting
uint PacketLogSwitchType 4
uint PACKET_LOG_ARP 0
uint PACKET_LOG_DHCP 1
uint PACKET_LOG_ETHERNET 0
uint PACKET_LOG_ICMP 0
uint PACKET_LOG_IP 0
uint PACKET_LOG_TCP 0
uint PACKET_LOG_TCP_CONN 1
uint PACKET_LOG_UDP 0
bool SavePacketLog false
bool SaveSecurityLog false
uint SecurityLogSwitchType 4
declare Message
declare Option
uint AdjustTcpMssValue 0
bool DisableHttpParsing false
bool DisableIPParsing false
bool DisableIpRawModeSecureNAT true
bool DisableKernelModeSecureNAT true
bool DisableUdpAcceleration true
bool DisableUserModeSecureNAT true
bool FilterBPDU false
bool FilterIPv4 false
bool FilterIPv6 false
bool FilterNonIP false
bool FilterOSPF false
bool FilterPPPoE false
bool ManageOnlyPrivateIP true
uint MaxSession 0
bool NoArpPolling false
bool NoEnum false
bool NoIpTable false
bool NoIPv4PacketLog false
bool NoIPv6AddrPolling false
bool NoIPv6PacketLog false
bool NoLookBPDUBridgeId false
bool NoMacAddressLog true
bool NoManageVlanId false
uint RequiredClientId 0
string VlanTypeId 0x8100
declare SecureNAT
bool Disabled true
bool SaveLog false
declare VirtualDhcpServer
string DhcpDnsServerAddress 0.0.0.0
string DhcpDomainName $
bool DhcpEnabled true
uint DhcpExpireTimeSpan 7200
string DhcpGatewayAddress 0.0.0.0
string DhcpLeaseIPEnd 10.50.254.254
string DhcpLeaseIPStart 10.50.250.1
string DhcpPushRoutes $
string DhcpSubnetMask 255.255.0.0
declare VirtualHost
string VirtualHostIp 10.50.0.1
string VirtualHostIpSubnetMask 255.255.0.0
string VirtualHostMacAddress 00-AC-4B-18-52-F5
declare VirtualRouter
bool NatEnabled false
uint NatMtu 1500
uint NatTcpTimeout 1800
uint NatUdpTimeout 60
declare CertList
declare CrlList
declare GroupList
declare IPAccessControlList
declare UserList
declare futura
byte AuthNtLmSecureHash 6NfFk3DJgZONzjUwnkD41g==
byte AuthPassword I6aV8PddUh1fKcbUXGrI+Meu1Mw=
uint AuthType 1
uint64 CreatedTime 1504522440793
uint64 ExpireTime 0
string Note futura
string RealName futura
uint64 UpdatedTime 1504522440793
declare Traffic
declare RecvTraffic
uint64 BroadcastBytes 21778479382341
uint64 BroadcastCount 165572863090
uint64 UnicastBytes 8463871214318
uint64 UnicastCount 29842535046
declare SendTraffic
uint64 BroadcastBytes 99218016046
uint64 BroadcastCount 841417965
uint64 UnicastBytes 8478361640656
uint64 UnicastCount 29996656617
declare Traffic
declare RecvTraffic
uint64 UnicastBytes 8478601494738
uint64 UnicastCount 29999059725
declare SendTraffic
uint64 BroadcastBytes 21871743363785
uint64 BroadcastCount 166301524873
uint64 UnicastBytes 8464163509235
uint64 UnicastCount 29846175763
declare VPNGate
string Abuse $
bool IsEnabled false
bool LogPermanent false
string Message $
bool NoLog false
string Owner q2zvgvk4fb.underdc.com.br's$20owner
Re: CPU 100%
Post by thisjun » Thu Feb 15, 2018 6:14 am
What OS did you use?
