linux vpnclient gets no ip from the dhcp server of the vpnserver
michaelriege
Post by michaelriege » Wed Feb 07, 2018 11:53 am
I had set up a softether vpnserver on linux, all windows clients run well, got the ips from the dhcp server. But I have one linux client installed, it connect to the same hub , but I got no ip out of the dhcp range, I defined.
On the linux client the vpn adapter has only an ip6 address and is a link to eth0.
Has anybody an idea?
diktus
Re: linux vpnclient gets no ip from the dhcp server of the vpnserver
Post by diktus » Fri Feb 09, 2018 3:05 am
Do you use virtual secure nat or local bridge? does the linux have virtual adapter? it should be has virtual adapter to get the DHCP from VPN Server
