installation of the virtual network adapter device failed
dantesaki05
Post by dantesaki05 » Wed Feb 07, 2018 3:36 pm
i didnt use any virus scanner i did run with administrator but it didnt work out
i use a private ip cuz my ISP is **** what can i do please help
Re: installation of the virtual network adapter device failed
Post by thisjun » Thu Mar 01, 2018 6:37 am
What OS did you use?
Impr0ve
Post by Impr0ve » Sun May 13, 2018 2:27 am
I have windows 10 and I tried to install the virtual network adapted and it failed for me also on both of my computers
Impr0ve
Post by Impr0ve » Sun May 13, 2018 4:48 am
does anybody know how to fix this?? maybe installing an older build or something?
Impr0ve
Post by Impr0ve » Sat Jun 16, 2018 1:36 am
I found A solution To get the network adapter installed. I had to go into cmd as administrator and run a sfc /scannow
and after that I put this command in Dism /online /Cleanup-Image /StartComponentCleanup twice and than did this one command DISM /Online /Cleanup-Image /AnalyzeComponentStore
I guess my windows got corrupted somehow but that worked for me you might to restart just thought I could put this on here just in case
anyone else might be having the same problem. hope this helps somebody :)
