Can't ping local TAP interface IP address on SoftEther server
t9false
Post by t9false » Mon Feb 12, 2018 12:04 pm
...but the connection is working fine. As in, vpnclient successfully connects to vpnserver and is able to communicate with it both ways, except ICMP ping.
Steps I've taken on vpnserver:
1) hubcreate testhub1
2) bridgecreate testhub1 /device:test1 /tap:yes
3) usercreate tuser1
4) userpasswordset tuser1 password
on vpnclient (this was an already working configuration, fully tested with a previous instance of vpnserver):
1) niccreate nic1
2) accountcreate tvpn1 /server:${vpnserver} /hub:testhub1 /username:tuser1 /password:password
At this point the "accountlist" on vpnclient and "sessionlist" on vpnserver both show me the active connection "Status: Connected".
Then I've manually set the IP address on both ends:
vpnserver: ifconfig tap_test1 192.168.10.1/24
vpnclient: ifconfig vpn_nic1 192.168.10.10/24
Now I can ping 192.168.10.10 from 192.168.10.1 no problem, but not the other way around. 192.168.10.1 can't even ping itself from a local console. Otherwise everything works fine: 192.168.10.10 can connect to 192.168.10.1 via ssh and other ports.
dmesg is empty. Either something went wrong on a rather low level (bridging maybe?) or I need to alter SoftEther settings.
Either way, any help is appreciated. Thank you.
Re: Can't ping local TAP interface IP address on SoftEther server
Post by thisjun » Thu Mar 01, 2018 7:33 am
Please check that the vpnclient is configured not answering ping or there is same IP address host in the same LAN.
