Windows Server 2012
GerdFunke
Windows Server 2012
Post by GerdFunke » Thu Feb 15, 2018 6:41 am
i had a Problem. I try everything to solve now over 1 Week but no success.
I install SoftEther Server on my Windows Server 2012. I use the Default configurations.
Port Number 5555, Direct TCP/IP Connection without Proxy.
I choose Remote Access VPN Server and Site-to-Site Server ( VPN Server that Accepts Connection from other Sites )
Virtual Hub i choose only Enable L2TP Server Function.
Create a user with Password Authentication
Configure the Local Bridge with the Adapter
Enable SecureNat
Everything OK ... works perfect ....
Then i install the Client Software on Windows 10
Configure the Client.
Connect to the Server.
Everything OK ... Connection is OK.
My Internet Acces now is routed over the Server.
OK ...
The private IP the Server gives to the Client is 192.168.30.10
The outside IP of the Server is 85.211.xxx.xxx
Everything OK till this steps.
But i cant see the Files and Directorys on the Server when i connect from the Client.
If i try to connect on Windows File System the System ask me for Windows User Name and Password.
I type this correct in. Answer from System "wrong user or wrong password" or nothing to see ...
It is not possible to use File Shares from Client.
I try to connect from client with 192.168.30.10 and with 192.168.30.1 and with the outside IP of the Server.
No success ...
Where is my mistake, i hope somebody can help me,
Best regards,
Gerd
Re: Windows Server 2012
Post by thisjun » Wed Mar 07, 2018 6:50 am
Why did you use SecureNAT instead of localbridge?
