use radius not works
somphol
Post by somphol » Wed Feb 28, 2018 6:56 pm
now i try to use softether windows 2012 and radius server and connext to radius ubuntu. i config
ubuntu X.X.X.X key l2vpn same softether on windows .when user connet vpn is Can't connect vpn
show message
"the remote connect was denied because the user name and password combination you provide is not recognized"
i check database user aaa pass 123456 when connect vpn in put user aaa pass 123456 i try check
softether SENT THIS MESSGE "@$^%$^$$^$^ IS NOT MATH IN DATABASE SO I CAN NOT CONNECT VPN
PLEASE HELP ME
somphol
radius
Post by somphol » Thu Mar 01, 2018 2:38 am
# Executing group from file /etc/freeradius/sites-enabled/default
+- entering group PAP {...}
[pap] login attempt with password "�$&?�V�??<?-`�?:"
[pap] Using clear text password "AB4321"
[pap] Passwords don't match
++[pap] returns reject
ogin attempt with password "�$&?�V�??<?-`�?:" << why
Re: use radius not works
Post by thisjun » Wed Mar 14, 2018 6:37 am
Did you check the log of the VPN server?
