Difference between IP you show and others show
jimeffindandy
Post by jimeffindandy » Fri Mar 02, 2018 5:37 am
Noob! Thanks for VPN Gate ’n related stuff. Old Mac running OS X 10.4. I configured Tunnelblick the way your pages showed and both that with OpenVPN and Internet Connect with L2TP work. http://www.vpngate.net/en/ gives me the changed IP but https://www.whatismyip.com/ and others of its ilk still show the original. What’s up?
jimeffindandy
Re: Difference between IP you show and others show
Post by jimeffindandy » Fri Mar 02, 2018 11:02 pm
Solved, well, kinda sorta… Shut off computer overnight. Today, http://whatismyip.host/my-ip-address-details correctly shows changed IP.
As of now, I’m unable to send email via Thunderbird 3, when connected, but Vuze 5.6 BitTorrent client seems to be working.
Brijesh
Contact:
Post by Brijesh » Sat Mar 03, 2018 5:01 am
what do you want to know or what do you want to tell. Your topic is not clear.
appzetta
Contact:
Post by appzetta » Tue Mar 27, 2018 2:59 am
Its more likely a browser cache issue. Open a private browser and then visit http://whatismyip.live or http://myipaddress.host or any similar website they will show you with changed IP address.
