RDP Sessios slow over VPN
skl
Post by skl » Mon Mar 12, 2018 1:12 pm
Hello guys,
I'm testing VPN Server as Remote Connection.
Routing, ping and throughput is ok.
However RDP sessions is very slow. Did packet pacture and saw a lot of TCP retransmissions (attached).
I saw this before in other tunneling situation because RDP is sensitive to fragmentation, where adjusting MTU resolved issue.
Could someone help me troubleshoot this case?
Environment:
Tested VPN Server in Ubuntu 14 and Centos 6.5.
Client connecting to VPN Server through HTTPS/443.
Firewall doing Full DNAT to Internal VPN Server.
Bridged to local LAN and getting IP from local DHCP Server.
RDP Server (2008 R2) is on the same network segment.
Re: RDP Sessios slow over VPN
Post by thisjun » Thu Mar 22, 2018 7:07 am
I think TCP retransmissions doesn't happen.
Each packet is sent just once.
Could you try to disable the NAT-T?
Because packet loss of UDP may cause this problem.
skl
Post by skl » Thu Mar 29, 2018 5:04 pm
I'm using vpn over HTTPS, tried with 5555, too.
Also, VPNServer is inside the branch network published with DNAT. And on client side there's a NAT but allowing all traffic to outgoing.
Post by thisjun » Wed Apr 18, 2018 7:04 am
Does SoftEther VPN client connect to the VPN server with TCP?
Could you confirm method of connection by log of VPN sever?
