Connection. terminated by the cause "User authentication failed." (code 9).
Zeland
Post by Zeland » Sun Mar 25, 2018 6:11 pm
People please help!
7 days I have a problem.
My client on Linux has the status of a connection
log server:
2018-03-25 17:50:09.324 On the TCP Listener (Port 443), a Client (IP address **.***.***.*, Host name "broadband-**.***.***.*.***********", Port number 60617) has connected.
2018-03-25 17:50:09.324 For the client (IP address: **.***.***.*, host name: "broadband-**.***.***.*.***********", port number: 60617), connection "CID-1212" has been created.
2018-03-25 17:50:09.394 SSL communication for connection "CID-1212" has been started. The encryption algorithm name is "AES128-SHA".
2018-03-25 17:50:09.523 [HUB "VPNHUB"] The connection "CID-1212" (IP address: **.***.***.*, Host name: "broadband-**.***.***.*.***********", Port number: 60617, Client name: "SoftEther VPN Client", Version: 4.25, Build: 9656) is attempting to connect to the Virtual Hub. The auth type provided is "Password authentication" and the user name is "test".
2018-03-25 17:50:09.523 [HUB "VPNHUB"] Connection "CID-1212": User authentication failed. The user name that has been provided was "test".
2018-03-25 17:50:09.557 Connection "CID-1212" terminated by the cause "User authentication failed." (code 9).
log client:
VPN connection Setting "VPNconnect": Connection operation starting (this is now 845 time)
VPN connection Setting "VPNconnect": Connection operation has been either disconnected or if failed. Cause: User authentication failed. (code 9)
ccountList the client
VPN connection Setting Name | VPNconnect
Status | Connecting
VPN Server Hostname | ***.**.**.***:443 (Direct TCP/IP Connection)
Virtual Hub | VPNHUB
Virtual Network Adapter Name | ethVPN
Please Help Me
Re: Connection. terminated by the cause "User authentication failed." (code 9).
Post by thisjun » Wed Apr 18, 2018 6:48 am
Please check configured password.
david0923
Post by david0923 » Fri Apr 20, 2018 4:50 am
what the script you used to set up ur ip to your website? dibian to softeter
