Setup my own Azure VPS?
spm
Post by spm » Wed Mar 28, 2018 3:25 pm
First of all, thank you for this software. It's a great tool and easy to set up.
In order to make a site-to-site connection to a remote network I have Azure VPN service enabled. However when using this service the speed is too slow for some applications. I would like to replicate the VPS setup using Azure servers closer to me. Can someone help me set this up on Azure? What tools do I need? How does SoftEther do it?
Thank you in advance for any help.
spm
Re: Setup my own Azure VPS?
Post by spm » Tue Apr 10, 2018 3:17 pm
Does anyone know how softether uses Azure to relay the VPN connection?
Post by thisjun » Fri Apr 27, 2018 3:25 am
SoftEther VPN Azure VPN service doesn't relate Windows Azure service.
I think you doesn't need any special tool.
Please set up SoftEther VPN server on a VPS usually.
spm
Post by spm » Fri Apr 27, 2018 7:55 pm
My apologies, I misunderstood what Azure was. I thought it related to the Azure cloud platform that Microsoft provides.
