VPN Server shows lokal IP
botti
Post by botti » Fri Apr 06, 2018 11:51 am
Hi all,
i use a VPN Server and the listener is set to port 443. The VPN Server is reachable via internet.
When i try to acccess its public IP (it is forwarded to the VPN Server internal IP) via Webbrowser, you can see to internal IP address from the Softether VPN Server.
Like this:
Forbidden
You don't have permission to access / on this server.
HTTP Server at 192.168.3.55 Port 443
How can i prevent it the display it´s internal IP?
Re: VPN Server shows lokal IP
Post by thisjun » Fri Apr 27, 2018 2:54 am
botti
Post by botti » Fri Apr 27, 2018 7:10 am
Thank you very much. Sadly i am not familar with compiling, but i have to do now :)
Looks not complicated but VS 2008 is needed..... Hm, i have a look on MSDN.
I thought there is an option i the config file to change this.
botti
Post by botti » Fri Apr 27, 2018 7:32 am
Yes I know. I'll try it. Also Minion Rush :)
It is a shame that Softether does not exist as a commercial product. There is no buyable solution that meets all our requirements. Only softether ......
Post by thisjun » Wed May 16, 2018 9:00 am
I recommend to post your improvement request to Github.
https://github.com/SoftEtherVPN/SoftEtherVPN/issues
