Can I share the Internet Connection of a Remote Host?
turnupdigital
Post by turnupdigital » Sat Apr 14, 2018 9:37 pm
Hello... I never post, ever I only loom absorbing information usually... but I am stumped and I think you fine folks can help me out.
I needed to group some servers that where not in the same location for web development purposes. I came across SoftEther while researching for a solution.
As I tried to understand how it worked more and more it seems like I should be able to use the internet connection from a remote host. Or at least share the internet connection of a remote host... How? what is the best way... I control the entire environment I have servers set up not admins or anyone overseeing me.
I know I can do it with windows server but it has to be with windows enterprise installed before I went that route I wanted to see it there is anyway to do it with SoftEther.
On the server I can turn on Internet Connection Sharing. This "Cascading" function seems to tell me that I can forward the internet connectivity to another hub or server... but I dont know.
My server is on a 1Gbps connection how can I share in that connection and have as close to that speed as possible from halfway around the world?
Your insight and assistance is appreciated.
Re: Can I share the Internet Connection of a Remote Host?
Post by thisjun » Wed May 16, 2018 7:59 am
There are two way.
If you have NATted network, using localbridge may be better.
http://www.softether.org/4-docs/2-howto ... VPN_to_LAN
If not, using SecureNAT may be better.
http://www.softether.org/4-docs/1-manua ... Permission
