There is no connection from vpncmd cli utility)
koypa
Post by koypa » Sun Apr 15, 2018 4:33 pm
Hello!
Sorry for my bad English, but i ll try to explain as easier as I can.
So, my problem.
I created SoftEther VPN Server on CentOS 7.
Then, i installed vpn client on my raspberry (and after it, on my PC and Mac, for tests).
When i connect to a virtual hub on server from Windows GUI Utility - there is no problem with connection, i have a clear VPN connection.
But when i try to connect from cli utility on my raspberry and cli utility from Mac - i have Error Code 1.
I have started a vpn client in my *nix-based systems by a command
# ./vpnclient start
but there is no effect.
Looking forward to hearing from you)))
Re: There is no connection from vpncmd cli utility)
Post by cedar » Thu Apr 19, 2018 10:03 am
If you want to manage the VPN Client from remote host, please enable remote management with vpncmd.
On default setting, a VPN Client denies remote management.
http://www.softether.org/4-docs/1-manua ... nt_Service
