Routing for dummies on OSX question
Yuri
Post by Yuri » Fri Apr 20, 2018 12:43 pm
Hi everyone!
I'm feeling like I'm using smth simple and stupid...
I got my CentOS server plus SoftEther VPN server installed on it.
Then I got VPN client installed on my OSX.
Client is connected: I see new interface named tap0 in ifconfig and Session Status is "Connection Completed (Session Established)".
Then I add an IP to tap0: sudo ipconfig set tap0 DHCP. Top0 interface now got an IP.
But what's next?
It's actually several questions:
1) what IP should I use for new default gateway for client machine? My server now has only two interfaces: lo and en0 (the internet connection), it does not have separate interface for VPN session...
2) I'd like to get old default interface/gateway and remember it, and be able to restore it after my vpnclient is down. how to do this?
3) can I manage all this from server's side as I got several OSX machines?
4) how can I get my session automatically try to get up and running after 'sudo vpnserver start' command?
PS: I would say that SoftEther VPN client OSX version is way more geeky then others, as others just work right after the installation without any routing table tricks. Why not to write some simple guide for OSX users?
Yuri
Re: Routing for dummies on OSX question
Post by Yuri » Sat Apr 21, 2018 3:14 pm
Guys, any update? Please!
Post by thisjun » Wed May 16, 2018 8:37 am
What do you want to do with VPN?
Yuri
Post by Yuri » Wed May 16, 2018 8:48 am
As usual: I’d like to put all the client traffic to the vpn tunnel.
Post by thisjun » Fri Jun 01, 2018 5:29 am
I recommend using OpenVPN client.
How about it?
https://tunnelblick.net/
Yuri
Post by Yuri » Fri Jun 01, 2018 9:50 am
OpenVPN is blocked by my internet provide. I use Outline now. It's not SoftEther but simple, reliable and well explained at forums ;)
Post by thisjun » Thu Jun 14, 2018 7:50 am
If your beginner, SecureNAT is an easy way but slow.
Please note that don't use localbridge and SecureNAT at the same time.
