Connection error (Error Code 23)
miglo
Post by miglo » Sat Apr 21, 2018 7:57 am
Error (Error Code 23):
An internal error occurred.
log:
2018-04-21 10:04:41.649 The connection with the client (IP address X.X.X.X, Port number 1523) has been disconnected.
2018-04-21 10:04:43.968 On the TCP Listener (Port 443), a Client (IP address X.X.X.X, Host name "X.X.X.X", Port number 1525) has connected.
2018-04-21 10:04:43.968 For the client (IP address: X.X.X.X, host name: "X.X.X.X", port number: 1525), connection "CID-29-69CDD9D394" has been created.
2018-04-21 10:04:43.992 SSL communication for connection "CID-29-69CDD9D394" has been started. The encryption algorithm name is "AES256-SHA".
2018-04-21 10:04:44.094 Connection "CID-29-69CDD9D394" terminated by the cause "An internal error occurred." (code 23).
2018-04-21 10:04:44.094 Connection "CID-29-69CDD9D394" has been terminated.
connection to other softether servers are passing.
Re: Connection error (Error Code 23)
Post by thisjun » Wed May 16, 2018 8:34 am
Can another VPN client connect to the VPN server?
Is the error message shown in VPN client?
