Force client to use password every time, and not save
foddergreenwood
Post by foddergreenwood » Fri Apr 27, 2018 4:40 pm
I have scenario where I wish user to have to enter password when connect to VPN, and not be able to save in client software. How is best way to accomplish this?
Re: Force client to use password every time, and not save
Post by thisjun » Wed May 16, 2018 9:07 am
As a dirty method, if you drop write permission of the setting file of the VPN client, you can prevent the password from being saved.
foddergreenwood
Post by foddergreenwood » Wed May 16, 2018 5:48 pm
That is a great idea. Just looked, and I don't immediately see a settings file. Would you know what it is called, and where it is located?
Thanks for the help!
foddergreenwood
Post by foddergreenwood » Wed May 16, 2018 6:15 pm
I just found it! Thanks again.
