Clients connected but no IP assigned DHCP
pitbox2308
Post by pitbox2308 » Fri May 04, 2018 9:17 pm
I have a VPN server on a physical machine and there are no issues connecting to it. But, when I built up a VM Win Server 2016 (Bridged Network) with AD our vpn users started experiencing DHCP assignment issue when they connect to the VPN gateway but no IP given from the internal network (only APIPA 169.254.). A VPN client displays a window "Requesting an IP address to the DHCP server in the VPN" then disappears so, nothing happens. I see that it is connected on the VPN server status. I have a router acting as the DHCP server. As soon as I shut down the VM and restart the VPN server it goes back to normal operational state...
Any ideas?
Thank you.
Re: Clients connected but no IP assigned DHCP
Post by thisjun » Wed May 23, 2018 7:10 am
Does the VM run on the same host of the VPN server?
