Connect to Internet through VPN Server
luizloyola
Post by luizloyola » Mon May 07, 2018 2:29 pm
I have a VPN Server up and working. I can connect through the port 443 and access the server and the other devices that are connected.
But I want to connect to the Internet through this server. What do I need to do?
biax
Re: Connect to Internet through VPN Server
Post by biax » Sat May 12, 2018 5:15 am
HAVING the exact problems and vvery freaking irritated by the docs.
WHATS THE POINT OF HAVING A VPN when you cant have a damn connection through it?
the docs are all over the place and doesn't guide you through typical use cases.
someone needs to learn how to write archlinux style guides here.
Post by thisjun » Fri Jun 01, 2018 4:25 am
Could you confirm that the default gateway is configured on the VPN client virtual NIC?
