How to Install VPN client - Lubuntu
smartersolutions
Post by smartersolutions » Mon May 07, 2018 5:36 pm
Hey guy,
Was wondering if anyone here has installed the VPN client on Lubuntu and if so how is it done?
I unpacked the files and have looked around the internet for details but cannot find the correct way because everything I find
seems to be incorrect.
Thanks
Re: How to Install VPN client - Lubuntu
Post by thisjun » Wed May 23, 2018 7:24 am
What error do you see?
saletrak
Post by saletrak » Wed May 23, 2018 4:37 pm
When you are in direcotry with unpacked VPN Client just use command: make
Then you can start VPN Client using: sudo ./vpnclient start
more info: https://www.softether.org/5-download/sr ... N_for_UNIX
