Cannot connect from Windows 10 with IPsec
3da
Post by 3da » Mon May 07, 2018 5:56 pm
My log on VPN Server (IP addresses removed):
2018-05-07 20:37:55.244 IPsec Client 37 (_ -> _): A new IPsec client is created.
2018-05-07 20:37:55.244 IPsec IKE Session (IKE SA) 11 (Client: 37) (_ -> _): A new IKE SA (Main Mode) is created. Initiator Cookie: 0x5A08636E947F86E, Responder Cookie: 0x6782AB857056368, DH Group: MODP 2048 (Group 14), Hash Algorithm: SHA-1, Cipher Algorithm: AES-CBC, Cipher Key Size: 256 bits, Lifetime: 4294967295 Kbytes or 28800 seconds
2018-05-07 20:37:55.411 IPsec Client 37 (_ -> _): The port number information of this client is updated.
2018-05-07 20:37:55.411 IPsec IKE Session (IKE SA) 11 (Client: 37) (_ -> _): This IKE SA is established between the server and the client.
2018-05-07 20:37:55.468 IPsec IKE Session (IKE SA) 11 (Client: 37) (_ -> _): The client initiates a QuickMode negotiation.
2018-05-07 20:37:55.468 IPsec ESP Session (IPsec SA) 11 (Client: 37) (_ -> _): A new IPsec SA (Direction: Client -> Server) is created. SPI: 0x4EC6C46C, DH Group: (null), Hash Algorithm: SHA-1, Cipher Algorithm: AES-CBC, Cipher Key Size: 256 bits, Lifetime: 250000 Kbytes or 3600 seconds
2018-05-07 20:37:55.469 IPsec ESP Session (IPsec SA) 11 (Client: 37) (_ -> _): A new IPsec SA (Direction: Server -> Client) is created. SPI: 0x2F40DA3A, DH Group: (null), Hash Algorithm: SHA-1, Cipher Algorithm: AES-CBC, Cipher Key Size: 256 bits, Lifetime: 250000 Kbytes or 3600 seconds
2018-05-07 20:37:55.524 IPsec ESP Session (IPsec SA) 11 (Client: 37) (_ -> _): This IPsec SA is established between the server and the client.
2018-05-07 20:37:55.525 IPsec Client 37 (_ -> _): The L2TP Server Module is started.
2018-05-07 20:37:55.645 IPsec ESP Session (IPsec SA) 11 (Client: 37) (_ -> _): This IPsec SA is deleted.
2018-05-07 20:37:55.646 IPsec IKE Session (IKE SA) 11 (Client: 37) (_ -> _): This IKE SA is deleted.
2018-05-07 20:37:55.646 IPsec ESP Session (IPsec SA) 11 (Client: 37) (_ -> _): This IPsec SA is deleted.
2018-05-07 20:38:06.054 IPsec Client 37 (_ -> _): This IPsec Client is deleted.
2018-05-07 20:38:27.994 Administration mode [RPC-2708]: The log file on the server "_" (log file "server_log/vpn_20180507.log") has been downloaded.
On windows I just got useless error message:
"модем или другое устройство связи сообщило об ошибке"
What do I do wrong?
Re: Cannot connect from Windows 10 with IPsec
Post by thisjun » Wed May 23, 2018 7:32 am
Could you tell me what configuration did you do in Windows 10?
