Help:using only 1 app with softether without VM
pegla2108001
Post by pegla2108001 » Thu May 10, 2018 3:43 pm
Theres a program I d like to use, but its blocked in my country.The catch is,I need to have that program open on my pc, otherwise I'd use a virtual machine.Have tried several solutions but none have worked so far.Any help is greatly appreciated.
Also should note:I d just use the VPN normally, but i wanna save bandwidth for games and such..
Re: Help:using only 1 app with softether without VM
Post by thisjun » Fri Jun 01, 2018 4:17 am
If you know the destination IP address which the app connect to, you can add the route to it via VPN into your PC.
