Painfully slow performance
magel282
Post by magel282 » Sat May 19, 2018 12:50 am
Hi there,
I have Softether running on a Surface Pro 3 i7 8gb of Ram Windows 10 x64.
I can remotely connect to the VPN using the client on my other computers however the connection is sssooo ssslllooww.
My home connection for the server is 100/40 fiber connection.
Remote machines use 4g connection.
Running a google speed test on a client machine while connected to the VPN has a download rate of less than 1mbps, typically 300-400kbps. Why is this the case? I have re-installed the server and clients multiple times.
I have set the server up using the default settings on the setup page. The only thing I have tried to change is disabling NAT-T on the clients and using data compression on the clients. Didn't help at all.
Please help. Thanks!!
Re: Painfully slow performance
Post by thisjun » Fri Jun 01, 2018 6:07 am
I don't recommend to use Data Compression function.
But, it may not impact such.
How throughput can you get between the remote device and the home without the VPN?
