L2 Bridge / Cascade connection from mikrotik -> Softether ?
nicknack
Post by nicknack » Sun May 20, 2018 5:39 am
Hi all...
Is there any method to make mikrotik connect to SE vpn bridge with cascade connection ?
I've tried all sstp and l2tp connection from mikrotik to SE, and it's all succeeded, but without success
propagating all connected lan behind mikrotik to be accessible.
Direct connection to mikrotik's local ip is ok, but not other lan subnet behind it..
Is that mean it can only be implemented with L3 vpn ?
Re: L2 Bridge / Cascade connection from mikrotik -> Softether ?
Post by thisjun » Fri Jun 01, 2018 6:15 am
I think you can achieve by using pushing route.
90gio
Post by 90gio » Wed Sep 05, 2018 7:26 am
Hi nicknack,
I have exactly your same problem. Can I know how you solved?
