I found a very good Japanese server on softether server list last month, and I kept a record of its ip and its port(which is 1204). I then set up the connection on Softether using the virtual hub VPNGATE, with TCP/IP connection, and username "vpn".
For that one week I was able to connect to that server every day I tried. Then one day I experienced "error code 1" when I tried to connect to that server, and since then it says "error code 1" whenever I tried to connect.
I really want to connect to that server again. Does anyone know the method to do that? Perhaps guessing another port or using other types of connections?
Thanks guys for the help!
saved VPN server error code 1
Re: saved VPN server error code 1
please help guys
really want to use that server
roberto wrote:
> I saw the same problem at this forum. Try to search here. I bet there is a
> decision somewhere.
I tried searching it up but because my question is too basic and general, the search engine wouldn't allow me to search the key words I want...
Can you please tell me some of the key words of that post you saw so I can search it up?
Or if it is possible please give me the link to that post.
Thank you very much!
> decision somewhere.
