[PLEASE HELP] DOWNLOAD SPEED VERY SLOW BUT THE UPLOAD IS OK
jvanegmond
Re: [PLEASE HELP] DOWNLOAD SPEED VERY SLOW BUT THE UPLOAD IS OK
Post by jvanegmond » Tue Jun 19, 2018 7:58 am
On the documentation page https://www.softether.org/1-features/2. ... -based_VPN the following is mentioned:
Local Bridges must be applied between a Virtual Hub and an Ethernet network adapter which is connected to the physical Ethernet switch. So in order to use Local Bridge you need dedicated physical Ethernet adapter. (In fact, the Ethernet adapter can be shared with other purpose, such as transmitting packets physically to the Internet in order to keep the VPN Session, but it is highly recommended to prepare a dedicated one due to performance matter.)
I'm having the same trouble with speeds and my next step will be to create a dedicated network card.
Kind regards,
jvanegmond
Post by thisjun » Thu Jun 28, 2018 5:59 am
What OS is used for the VPN server?
What mode is SecureNAT in?
Does the VPN server work on VM?
