Clustering Problems
nejnej25
Clustering Problems
Post by nejnej25 » Wed Jul 11, 2018 2:16 am
Hi I am building softether vpn, right now I am trying to cluster (1 controller, 1 member)
They are successfully clustered and all the incoming connection will be loaded only on the member.
I see some issue here:
1. I cannot set the protocol L2TP/IPSec it is greyed out.
2. Thru softether vpn client I connect to the server and it successfully connected but no internet (Public IP does not changed).
Here are my problem right now. Please anyone help me. Thank you
Btw, Im running ubuntu 16 as my server for additional information.
Re: Clustering Problems
Post by thisjun » Wed Jul 18, 2018 7:14 am
L2TP/IPSec can't be used with clustering mode.
Please create localbridge.
Johnmartin
Contact:
Post by Johnmartin » Mon Aug 06, 2018 10:00 am
Difference to more adaptable bunching techniques. Bayesian probabilistic models, for example, require complex testing plans or variational derivation calculations that can be hard to execute and comprehend, and are frequently not computationally tractable for vast informational indexes.
If anyone want help in homework writing, you can visit here | https://www.gethomeworkonline.com
