Ubuntu 18 SoftEther Client Adapter UNKNOWN Status
LilHabbitzz
Post by LilHabbitzz » Wed Jul 11, 2018 9:49 am
I am using SoftEther VPN Client and it says that I am connected to VPN but what my adapter says is different.
1. Management of VPN Server or VPN Bridge
2. Management of VPN Client
3. Use of VPN Tools (certificate creation and Network Traffic Speed Test Tool)
Select 1, 2 or 3: 2
Specify the host name or IP address of the computer that the destination VPN Client is operating on.
If nothing is input and Enter is pressed, connection will be made to localhost (this computer).
Hostname of IP Address of Destination: localhost
Connected to VPN Client "localhost".
VPN Client>remoteenable
RemoteEnable command - Allow Remote Management of VPN Client Service
VPN Client>accountlist
AccountList command - Get List of VPN Connection Settings
Item |Value
VPN Connection Setting Name |vpn
Status |Connected
VPN Server Hostname |x.x.x.x:5555 (Direct TCP/IP Connection)
Virtual Hub |VPN
Virtual Network Adapter Name|vpn
VPN Connection Setting Name |vpn (2)
Status |Offline
Virtual Hub |VPN
VPN Client>accountconnect vpn
AccountConnect command - Start Connection to VPN Server using VPN Connection Setting
Error occurred. (Error code: 35)
The specified VPN Connection Setting is currently connected.
VPN Client>
when I try the ip a command
6: vpn_vpn: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
link/ether 5e:1f:d0:13:71:26 brd ff:ff:ff:ff:ff:ff
inet 192.168.30.10/24 brd 192.168.30.255 scope global vpn_vpn
valid_lft forever preferred_lft forever
inet6 fe80::5c1f:d0ff:fe13:7126/64 scope link
It says state UNKNOWN.
I am following this thread too https://www.aspkin.com/forums/ip-addres ... toral.html
Any help will be much appreciated.
Re: Ubuntu 18 SoftEther Client Adapter UNKNOWN Status
Post by thisjun » Wed Jul 18, 2018 7:17 am
The IP address is assigned.
I think it works correctly.
LilHabbitzz
Post by LilHabbitzz » Thu Aug 16, 2018 2:40 am
But I don't received any packets :(
Post by thisjun » Thu Sep 13, 2018 6:11 am
There isn't adding the static route to the VPN server in the tutorial that you show.
