Run vpngate on linux ?
moham_96
Post by moham_96 » Tue Jul 17, 2018 10:45 am
I'm running softether vpn on linux, I'm running the command line vpnclient as a service and using the windows gui to remote control this service(the windows GUI is installed through wine) and I can add servers and connect, no problem, but I have to add servers manually from the vpngate.net website, is there a way I can install the vpngate plugin to the softether program (in wine)?
Thanks
