VPN Azure Cloud
iw4ens
VPN Azure Cloud
Post by iw4ens » Thu Aug 02, 2018 10:13 am
Hello, i have a Softethern VPN (Layer2) server running on ARM and connect it using AZURE because no pubblic ip neither on server or client side.
1) Now i have rent a VPS running linux, witch software i have to install on to make a VPN session relay server like Azure ?
2) how configure Softethern to use my VPN session relay?
I have tried install a squid on VPS and tell the Softethern use a proxy but scare resalt.
tanks for all hints you will provide
sorry for my bad English
Roberto
Re: VPN Azure Cloud
Post by thisjun » Wed Sep 05, 2018 6:59 am
1. Install SoftEther VPN Server on the VPS.
2. Create virtual hub on the VPN server of the VPS.
3. Create a cascade session from the existing VPN server to the VPN server on the VPS.
itskv
Re: VPN Azure Cloud
Post by itskv » Mon Sep 24, 2018 6:39 am
Exactly,...
Using Softether server application itself on VPS in CASCADING it with ARM server will do the magic.
However, can't you use your VPS directly as VPN server?? Whats need to relay the connection?
