Static routing definition (what is it?)
zaf
Post by zaf » Sat Aug 04, 2018 7:24 pm
Can the static routing table sort of tell a client to use its normal network adapter instead of the VPN? For example if i want all traffic headed for 128.42.10.133 to go through the client's regular ethernet adapter instead of through the vpn. Is that what its for?
centeredki69
Re: Static routing definition (what is it?)
Post by centeredki69 » Sun Aug 05, 2018 12:56 pm
Static routing I believe is generally used to tell One network subnet how to find and communicate with a second network subnet.
ie. network 192.168.1.0/24 has no idea where to find network 192.168.10.0/24. a static route can be set in a router to provide the path so the network can find each other.
READ THIS : https://www.grandmetric.com/2017/08/25/ ... c-routing/
zaf
Post by zaf » Mon Aug 06, 2018 4:40 am
Thanks for the link.
Post by thisjun » Wed Sep 05, 2018 7:26 am
Do you need routing on the VPN side?
If not so, please increase of the metric value of virtual NIC.
