Performance Throughput locked at 30Mbps?
vpnnew123
Post by vpnnew123 » Sun Aug 05, 2018 7:57 pm
we are currently evaluating softether vpn for connecting a remote site via l2 bridge. The software is pretty awesome. We tested using two raspberry pi 3+ with an ADSL 100Mbit (100 up / 30 down) connection. For throughput testing I used iperf on two windows boxes, one being at the remote site and one at our central site. For some reason up and download speed is locked at 30Mbps. Is the raspberry Pi or the 30Mbps upload the culprit here?
centeredki69
Re: Performance Throughput locked at 30Mbps?
Post by centeredki69 » Mon Aug 06, 2018 9:41 pm
Are you sure its ADSL 100Mbit (100 up / 30 down) connection? Most ADLS services have a higher Download then upload.
Do both locations have the same ADSL 100Mbit (100 up / 30 down) connection? If so it's the 30 Mbps internet service you have.
Your download will only be as fast as your download 30 Mbps and then the other sites upload 100 Mbps. The max transmission will be 30 Mbps
The other sites download will only be as fast as its download 30 Mbps and then your upload 100 Mbps. The max transmission will be 30 Mbps
The slowest speed is the max in any given direction.
