Cannot connect through UDP
zaf
Post by zaf » Tue Aug 07, 2018 4:30 am
Have a Softether server with tcp/udp port 992 opened. Connecting to it through tcp is fine but i cant seem to connect through udp, it just gets stuck in the connecting phase. I used the "/" at the end of the server name.
Re: Cannot connect through UDP
Post by thisjun » Wed Sep 05, 2018 7:39 am
The port number of UDP can't be specified in SoftEther VPN. (Except for OpenVPN)
The UDP port number is determined in UDP-hole-punching protocol.
