Unable to access remote machines
PedroCavaleiro
Post by PedroCavaleiro » Wed Aug 08, 2018 1:57 am
I've installed SftEther VPN Server on a Windows 10 machine (ip addr 192.168.1.200)
From my other machine outside the network I can connect to the VPN without a problem but can not access to any machine even the VPN server it self
Server Location
Router (192.168.1.1, 255.255.255.0)
VPN Server (192.168.1.200)
Remote Network
Client IP [real] (192.168.1.2)
Client IP [vpn] (192.168.1.233)
The client machine is running macOS High Sierra and I tried to connect using macOS's L2TP/IPSec (it connects sucessfully and routes the webpages to the VPN) but can not access any machine on the Server Network, Also tryed TunnelBlick with no luck, I ticked the "Route all IPv4 traffic through VPN" on my mac still when I type the IP it resolves to the Network on witch the mac is connected instead of the VPN
centeredki69
Re: Unable to access remote machines
Post by centeredki69 » Wed Aug 08, 2018 3:45 pm
You need to create a " LOCAL BRIDGE"
https://www.softether.org/4-docs/1-manu ... al_Bridges
