I understand systemd is the preference for services with latest version of Ubuntu. However, with the SE in Local Bridge mode how would you add the tap IP to the systemd script?
This is the working init.d script, but not sure how this would work when using systemd. Any advice?
# #!/bin/sh
### BEGIN INIT INFO
# Provides: vpnserver
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start daemon at boot time
# Description: Enable Softether by daemon.
### END INIT INFO
DAEMON=/usr/local/vpnserver/vpnserver
LOCK=/var/lock/subsys/vpnserver
TAP_ADDR=192.168.30.1
test -x $DAEMON || exit 0
case "$1" in
start)
$DAEMON start
touch $LOCK
sleep 1
/sbin/ifconfig tap_tapint1 $TAP_ADDR
stop)
$DAEMON stop
rm $LOCK
restart)
$DAEMON stop
sleep 3
$DAEMON start
sleep 1
echo "Usage: $0 {start|stop|restart}"
exit 1
esac
exit 0
