Unable to select AES cipher using vpncmd (ServerCipherSet)
itssiraj
Post by itssiraj » Sat Aug 18, 2018 4:33 am
I am using SoftEther VPN 4.27 Build 9668 Beta and I have changed the encryption algorithm to (although by default it is selected)
AES128-SHA
Even in server logs a change is depicted. "A new encryption algorithm name for the server has been set. The new encryption algorithm name is AES128-SHA"
When i login the softether vpn utility using vpncmd then then server logs show "A new encryption algorithm is AES128-SHA" however when softether vpn client connects to softether vpn server then the encryption algorithm is null "SSL communication for connection CID-16 has been started. The encryption algorithm name is (null)".
Even the properties of my windows native client shows that i am using ISEC AES 256.
Please guide
Re: Unable to select AES cipher using vpncmd (ServerCipherSet)
Post by thisjun » Thu Sep 13, 2018 6:14 am
What version of SoftEther VPN Client do you use?
