Assign Static IP to Windows Clinet
mrpine
Post by mrpine » Thu Aug 23, 2018 6:50 am
I have setup localbridg with an external dhcp server.(my softwether have 2 nics. one for client connection and another for bridge ). All Clients are working correctly. but wan to assign to specific client static ip .
I setup static IP address in my windows 10 tcp/ip connection and when try to connect it disconnect at registering connection step. my server says:
2018-08-23 11:17:59.863 L2TP PPP Session [172.16.5.119:1701]: Acquiring the networking information from the DHCP server failed. To accept a PPP session, you need to have a DHCP server. Make sure that a DHCP server is working normally in the Ethernet segment which the Virtual Hub belongs to. If you do not have a DHCP server, you can use the Virtual DHCP function of the SecureNAT on the Virtual Hub instead.
2018-08-23 11:18:00.076 L2TP PPP Session [172.16.5.119:1701]: The VPN Client sent a packet though an IP address of the VPN Client hasn't been determined.
2018-08-23 11:18:00.076 L2TP PPP Session [172.16.5.119:1701]: A PPP protocol error occurred, or the PPP session has been disconnected.
It seems that my client wait to get dhcp ip address , although I set static ip in my connection.
Any Help?!
Re: Assign Static IP to Windows Clinet
Post by thisjun » Thu Sep 13, 2018 6:41 am
Please refer to this topic.
viewtopic.php?f=7&t=2764
