vpn connection problem
duke
Post by duke » Fri Aug 31, 2018 11:51 am
Hallo to all!
Last week I tryed to create VPN with softether software in my factory.
I have installed VPN Server in a PC that I use like bridge to connect various PLC; then I have installed VPN Client in a Notebook.
As long as I am connected in the same network (in my factory) all is running well, but if I try to connect to server VPN from my home, I am not able to connect to the server.I have also tryed with azure cloud but without succeeding to connect (also in my factory).
Can you help me?
duke
Re: vpn connection problem
Post by duke » Sat Sep 01, 2018 12:35 pm
Anyone??
duke
Post by duke » Tue Sep 04, 2018 3:41 pm
:O
duke
Post by duke » Wed Sep 05, 2018 9:06 am
Nothing for me?
This is because in my project I cannot use "port forwarding": I have not access to router/firewall and the azure cloude may be the best solution!!
duke
Post by duke » Thu Sep 06, 2018 7:06 am
Thanks for reply AgnessaMark: yes, my connection run very well with 30Mb in download and 3.5 in upload.
Also if I ping Google dns there is no problem.
duke
Post by duke » Mon Sep 10, 2018 7:46 pm
I'sorry but I'm no able to use azure cloud: always connnect/disconnect...
