VPN Bridge crashes after ~ 10 seconds file transfer
Gee
Post by Gee » Tue Sep 04, 2018 11:56 am
hello, i have VPN Bridge installed on a arm x64 Box under Debian stretch. Compiled, installed, worked all fine..
Now the Box with installed Bridge has moved from Germany to Austria. the first problem is that i must manualy restart the VPN Bridge service to sucessfully connect to my VPN Server. And the second: as a connection test i init a windows file transfer from server to client via the bridge. It runs fast (around 7MByte /s) but after ~10 sec. of file transfer the Box crashes and i have to reconnect the power supply. Box isnt accessable via SSH then.. Logs show no errors..
i have testet the same procedere in another location and it works fine for hours..
UDP Acceleration on / off makes no difference
Any idea?
