Softether built on AWS EC2, observing current sessions never exceed 50???
donaldii
Post by donaldii » Tue Sep 11, 2018 5:56 pm
Hi VPN masters,
I have set up a softether server on Amazon EC2 and have been observing the performance for days. For sake of user experience, I am using the same username/password hard coded in client, so all users are sharing the same.
I have observed that the softether VPN sessions never exceeds 50, even though after I have explicitly set 'multiple login limit' to 65535. Through google I can't find any limitations set by Amazon EC2, so I'm asking gurus here whether you are aware of any settings I should change, in order to remove the 50 session limitation.
Sincerely thank you for any inputs.
Donaldii
P.S. I am fairly sure there are more than 50 people tried connecting to this server at the same time
donaldii
Re: Softether built on AWS EC2, observing current sessions never exceed 50???
Post by donaldii » Mon Sep 17, 2018 5:39 pm
Any input will be much appreciated!
EDIT: Have checked with AWS support but they said they have no settings related to this 50 limitation.
donaldii
Post by donaldii » Wed Sep 19, 2018 10:41 am
Post by thisjun » Wed Oct 17, 2018 6:38 am
Did you configure any quota?
