I have a Note 8 smartphone that will not connect to my VPN server. I also have a Note 4 and an iPad that do connect, so I am fairly certain that my problem is due to something going on in the Note 8. My VPN is for personal use and does not use any filters or access lists. Can anyone help with this?
Samsung Note 8 Model SM-N950U
Android 8.0.0
VPN: L2TP/IPSec/PSK
SoftEther V4.23 Build 9647
Verizon Note 8 will not connect to my VPN server
Re: Verizon Note 8 will not connect to my VPN server
Problem fixed......upgrade to SoftEther V4.28 solved the problem. I hope this is useful to others if they experience this issue.
Many thanks,
Many thanks,
