Connecting Meraki?
jkang
Connecting Meraki?
Post by jkang » Fri Sep 14, 2018 6:37 pm
We're trying to set up our Meraki VPN appliance with softether, because the Win10 built in VPN client is abysmal and breaks often. I've found softether recommended. How do I get my configuration to work? I don't see any field to enter a pre-shared key. I was just able to find fields to enter the hostname and username/password. What other settings need to be configured?
Re: Connecting Meraki?
Post by thisjun » Wed Oct 17, 2018 6:13 am
Do you want to connect SoftEther VPN Client to the Meraki?
If so, it's impossible because SoftEther VPN Client doesn't support IPSec.
