how to check connections?
sky59
Post by sky59 » Tue Sep 25, 2018 11:19 am
I have made two boxes:
- server
- bridge
both pass sucessfully "Network test" (check) using vpncmd.
whatever I check with windows manager everywhere is Online....
but bridge is repeating retries to connect to server saying I should check network connection, but test already passed !?
What excaclty is the check command checking with Network? Does it check also that ports are not blocked?
Is there any way to check and find where the problem is?
my "bridge" has got default virtual hub BRIDGE, my "server" has got hub VPN, I provided all info to the bridge including user and so on....
unfortunately logs are not saying too much? is there any possibility something like "ping" to check availability of server?
Re: how to check connections?
Post by thisjun » Wed Oct 17, 2018 7:41 am
Network check of vpncmd tests only binary integrity but not network environment.
