Recognizing Cellular Modem
SkinnyFRS
Post by SkinnyFRS » Wed Sep 26, 2018 1:39 pm
I have two new Microsoft Edge computers. They have an internal cellular broadband modem (new feature). The SoftEther client will not recognized the cellular broadband modem or at least I cannot get it to. I was wondering if there was any workarounds or if I'm just missing a setting somewhere.
SkinnyFRS
Re: Recognizing Cellular Modem
Post by SkinnyFRS » Wed Sep 26, 2018 7:02 pm
So did a bit of troubleshooting and found that the cellular adapter is the only one that does not have the ethersoft lightweight network protocol .inf file. I was wondering where I could find this file.
Brewster
Post by Brewster » Fri Sep 28, 2018 11:12 am
Did you sort this out, SkinnyFRS? I'm missing the .inf file as well.
Post by thisjun » Wed Oct 17, 2018 8:07 am
What does mean "SoftEther VPN recognize the cellular modem"?
There isn't entry to specify network connection.
SkinnyFRS
Post by SkinnyFRS » Mon Nov 19, 2018 8:57 pm
I'm still having trouble with it. This project got put on the back burner.
SkinnyFRS
Post by SkinnyFRS » Mon Nov 19, 2018 8:59 pm
Right, I'm having trouble getting the Soft Ether client to recognize the embedded cellular modem and for this reason it is not able to connect to the remote network. The client automatically recognizes ethernet and wi-fi but it will not recognize the embedded cellular modem and I am not able to install it manually.
sky59
Post by sky59 » Tue Nov 20, 2018 7:41 pm
Modem must be recognized by the system, linux/windows? Softether is just application that uses existing interface within the operating system.
I have under linux 3g modem and no problem, but SE is not accessing it, i created local bridge to it with SE
SkinnyFRS
Post by SkinnyFRS » Tue Nov 20, 2018 9:28 pm
System is Windows 10. The embedded modem is recognized by the system. I am able to access it with the windows VPN client.
SE client sees it under network devices but is unable to create a bridge to it. It just is not there under the selections when creating a bridge. The wi-fi and the ethernet ports are the only devices that are available when creating a bridge.
Also, we were able to connect the SE client to the SE server via wi-fi and ethernet, and the embedded cellular modem is able to ping the router; we are just having trouble tunneling.
Post by thisjun » Tue Dec 11, 2018 2:32 am
Naturally, a cellular network can't create a bridge because it isn't ethernet.
Why do you want to create a bridge?
