To troubleshoot problems I am having accessing SMB shares across the VPN, I thought I would install the SoftEther VPN client (I was using native Windows 10 VPN functionality).
Does the SoftEther Windows client allow entry of the Pre-Shared key? I cannot find it in the main or advanced properties screens.
I am on build 9669.
Thank you for your help.
SoftEther Windows Client Pre-shared Key
Re: SoftEther Windows Client Pre-shared Key
I'm guessing your issue is you not making a Cert for your user inside the virtual hub. for this to work you need to make 2 cert and private key pairs. One for the server/client (which is pretty easy to figure out).... And a second cert for your user that is signed by the first cert.
To make the User cert you have to go into server manager/Manage Virtual Hub/Manage Users/select the username/Edit/Create Certificate.
Then you need to sign the User Cert with the Server/Client Cert. Its self explanatory as long as you already made the Server/Client Cert and it's on your computer.
Then once you have the User Cert go into SoftEther Client manager/right click your connection/Properties/Auth Type select Client Certificate Authentication
And load your User Cert that is signed by the Server/Client Cert...
I know its hard as hell to get help like this, if you want, I just recently set up a discord server (instant messenger chat) (you don't have to download the app). I can walk you through it faster there.
here's a invite link: https://discord.gg/QByKXA9
