Remote SE Client Manager
cmd wh0ami
Post by cmd wh0ami » Wed Oct 10, 2018 2:21 am
What port does remote client manager use? I can get it to work on my linux host if I set a default accept policy in iptables. I'd like to make something a little more secure and permanent.
Also can someone tell me what "bool disable relay server" is all about... On my linux client it was set to false on default which is confusing and possibly a little concerning... I'm thinking it has something to do with VPN Gate? Since all the other settings for VPN Gate are below.
cmd wh0ami
Re: Remote SE Client Manager
Post by cmd wh0ami » Wed Oct 10, 2018 1:43 pm
I got iptables working... But it's not optimal...
 # Accept on local network
iptables -A INPUT -s 192.168.0.1/24 -j ACCEPT
Is there a better way in case I connect to another network where the network is on a different subnet like 192.168.1.0/24 ect?
cmd wh0ami
Post by cmd wh0ami » Wed Oct 10, 2018 4:46 pm
I think I have the iptables figured out...
iptables -A INPUT $(ip route list exact 0.0.0.0/0 | grep wlan0 | xargs | awk '{print $3}')/24 -j ACCEPT
Post by thisjun » Thu Oct 18, 2018 7:44 am
DisableRelayServer doesn't relate to VPN Gate.
https://github.com/SoftEtherVPN/SoftEth ... elayServer
Management port generating code is here.
https://github.com/SoftEtherVPN/SoftEth ... nt.c#L5290
