VPN Server Access and other permissions (ACL)
sajer
Post by sajer » Tue Oct 16, 2018 12:24 pm
Dear Forum Users,
i recently found this beautifull vpn softvare, and i want to use it for client-server Access.
How i'd like to use it: i would install this software on a seperate smaller machine, and than use only rdp to the terminal server.
How can i achieve theese two things:
-Only RDP Access for the users (or maybe for one Group, if Group right work properly)
-NO Access to the vpn server itself
I checked already some post out, but i cannot get it to work. (virtualhib->manage Access list)
I'm not using SecureNAT, the DHCP server itself gives IP addresses to the connecting users.
Everything Works fine, but i want to restrict the Access, for only RDP usage,after that they can rdp into the terminal server and that the vpn server itself shouldnt be accessieble for vpn users. I know this is not a hard thing, but i still cannot get it to work ^^
Thank you in advance guys and girls. Have a nice day
sajer
sajer
Re: VPN Server Access and other permissions (ACL)
Post by sajer » Tue Oct 16, 2018 12:33 pm
Basically, it would be easier, to only grant Access to only one (destination) computer (IP address), and only the "rdp port".
How could i achieve this? Thank you in advance
sajer
Post by sajer » Tue Oct 16, 2018 2:43 pm
i did this, this way i get ip address from dhcp server, but cannot Access the rdp server.
What do ido wrong?
https://imgur.com/a/va7DFHM
Post by thisjun » Thu Oct 25, 2018 6:22 am
Please create the following policies.
